Zum Hauptinhalt wechseln
Reparaturinformationen für den iMac G4.
My iMac G4 screen is not straight
Is there a way to straighten the display. Mine is slightly sagging downward on the right hand side of the display.
The screen is not tight and can be wiggled left and right
Notice the wiggle room on the top hinge of the arm.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Is the mount loose?
Post a pic or two so we can see clearly the defect. Use a ruler if that helps Bilder zu einer vorhandenen Frage hinzufügen
von
Hi Dan, I have added some photos and tried to describe the issue in greater detail.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
So the mount is loose! There is a set of nylon washers which wear out so the joints flex. You’ll need to take the mount apart which is a bit of a task! You’ll need a set of special tools from these folks iMac G4 neck disassembly tools (for the proprietary 3-prong screws, custom designed and 3D printed) if they still have them or you’ll need to make your own.
After taking the neck off and opened up you’ll see the washers. This is the hard part as you’ll need to find something that you can fit in to replace the worn washers.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Pieter Hartzenberg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 28
Insgesamt: 1,052
