Why turntable works and but nothing is coming out speakers
The needle is on the record with the needle guard off but still no sound through the speakers.
Ist dies eine gute Frage?
Hi @ mitchell schmidt 21
You will have to open it up and and use an Ohmmeter to check the connections from the needle cartridge all the way through to the control board preamp input.
If that is OK then the control board needs to be checked, initially for any obvious problems such as burnt out components, loose wiring or dry joint solder connections etc and then "live" testing may be necessary.
if you spot something (or even not) and are not quite sure post some close up images back here. Here's how to do this Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 376
Hi,
Do you get audio when plugging headphones into the headphone jack or if you connect the turntable's Line Out audio connections to an external sound system?
von jayeff
No unfortunately I try that and it still didn't work
von mitchell schmidt 21
