Zum Hauptinhalt wechseln
Repair information and troubleshooting for the Dell Latitude E5570. This is a 15.6 inch business class laptop computer with a 6th generation Intel Core processor. It was released in 2016.
8 Fragen Alle anzeigen
Wondering whether battery is upgradeable?
I don’t know whether i can “add” this information to device page, so i wanted to CONFIRM, that as long as you have M.2 storage in your e5570, uprade of 6MT4T (7.6V/ 62Wh) IS POSSIBLE.
I’ve bought 11,4V 84Wh (9-cell) WJ5R2 model and just replaced old one.
What is important: you have to buy with dedicated battery-board cable, as latter isn’t compatible with bigger cell.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Generally speaking with E5 Series machines, it depends on the drive setup. The HDD based ones tend to have a smaller battery since Dell uses part of the battery bay for the drive, but if you have one with a card SSD you can fit a larger battery in BUT you cannot have a second drive. This is the golden rule for pretty much all of them.
On the NVMe generations, it’s not an issue because the drives are worthwhile but on the mSATA ones, you’re better off dealing with the capacity compromise since mSATA is such a garbage standard.
War diese Antwort hilfreich?
Bewertung 0
I know on older laptops before they went to internal batteries, you could buy upgraded ones but they were physically larger. I know dell doesn’t sell batteries for their laptops if they’re internal and want you to send it back claiming it’s “too difficult” to replace when it’s just a handful of screws and no glue.
Bewertung 0
Antwort hinzufügen
Mike Litoris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 415
