Zum Hauptinhalt wechseln
Das März 2015 Update bringt jetzt die fünfte Generation der Intel Core i5 und i7 Prozessoren in das Apple 13" MacBook Air, dadurch wird die Leistung und die Akkulaufzeit etwas verbessert.
623 Fragen Alle anzeigen
Keyboard not lighting up
Hello,
I’ve noticed over the last few day that the keyboard on my MacBook Air Early 2015 isn’t lit up at all despite it saying it is on full when I press F6. This has come on suddenly.
I’m assuming it might be a connection issue somewhere, especially if it is allowing me to alter the brightness settings for the keyboard but I could be wrong. When I press F5 and F6 it isn’t doing anything but presents as if it is changing the brightness.
Any help and advice is appreciated! :)
Cheers,
James
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Could be the cable has become dislodged. The cable for the backlight is beside the keyboard connector on these, between that and the battery.
Before opening it up, and you’ve probably already done this, check that the ‘adjust keyboard in low light’ box in the keyboard settings in preferences isn’t ticked.
War diese Antwort hilfreich?
Bewertung 0
8 Kommentare:
Thank you for this. How do I access the keyboard connector? I've tried to Google it but couldn't find an answer. I've taken the back case off.
von
I took the battery out and it all seems to be plugged in
von
@jamcam - Review this guide MacBook Air 13" Anfang 2015 Logic Board austauschen first disconnect the battery following the first treen steps then jump down to Step 24.
von
@danj Cheers Dan. I just had a look and it is plugged in. I took it out and put it back in but unfortunately the lights still won't come on.
von
@jamcam - did you try resetting the SMC yet?
You'll need to check the voltage at the pins. If you get power then the keyboard backlight plate is damaged if you don't then the backlight power logic on the logic board is damaged and will need repairs.
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
James wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 98
