Hi Mayer,
Here is an excerpt of an answer to a similar question which I believe answers yours.
“All MacBook generations after the original MacBook1,1 Core Duo 1.83-2GHz one will run OS X 10.7 (the original MacBook will only run 10.6.8). The three generations shipping in 2007 top out at OS X 10.7.5. The only A1181 MacBooks that will run 10.8 or later are the Early and Mid 2009.”
What is the highest OS X I can run?
Hi Mayer,
Some research into this problem has clarified the issue and potentially solved it?
Lets break down what would prevent you upgrading an old MacBook:
The limiting factor for upgrading an old MacBook is its processors system architecture. Specifically the lack of support for SSE4.1. MacBook Models with a Merom intel core do not support this and as such are structurally incompatible with operating systems past 10.8+.
Luckily, some research into the model of computer you have (MB404LL/A) states that it was one of the few early 2008 MacBook laptops with a Penryn CPU!
However, keep this in mind:
Penryn CPU models T8100, T8300, T9300, T9500 are Penryn processors designed for Santa Rosa Refresh platforms with maximum FSB of 800 MT/s, whereas the rest of the Penryn processors are designed for Montevina platforms that can go up to maximum FSB of 1066 MT/s.
I do not know if this will be an issue when trying to run a newer operating system.
It is also worth noting that the later versions of MacBooks with Penryn CPUs which are “Unofficially” updatable do not use these processors:
Not “Unofficially” Compatible
- MacBook "Core 2 Duo" 2.1 13" (White-08)2.1 GHz Core 2 Duo (T8100)
- MacBook "Core 2 Duo" 2.4 13" (White-08)2.4 GHz Core 2 Duo (T8300)
- MacBook "Core 2 Duo" 2.4 13" (Black-08)2.4 GHz Core 2 Duo (T8300)
- MacBook "Core 2 Duo" 2.0 13" (Unibody)2.0 GHz Core 2 Duo (P7350)
- MacBook "Core 2 Duo" 2.4 13" (Unibody)2.4 GHz Core 2 Duo (P8600)
- MacBook "Core 2 Duo" 2.0 13" (White-09)2.0 GHz Core 2 Duo (P7350)
- MacBook "Core 2 Duo" 2.13 13" (White-09)2.13 GHz Core 2 Duo (P7450)
- MacBook "Core 2 Duo" 2.26 13" (Uni/Late 09)2.26 GHz Core 2 Duo (P7550)
- MacBook "Core 2 Duo" 2.4 13" (Mid-2010)2.4 GHz Core 2 Duo (P8600)
However, according to LowEndMac.com These MacBook Pro's released in 2008 are also supported, and if you notice, one of them is also running the T8300!
- MacBook Pro 15" "Core 2 Duo" 2.4 (08)2.4 GHz Core 2 Duo (T8300)
- MacBook Pro 15" "Core 2 Duo" 2.5 (08)2.5 GHz Core 2 Duo (T9300)
- MacBook Pro 15" "Core 2 Duo" 2.6 (08)2.6 GHz Core 2 Duo (T9500)
- MacBook Pro 17" "Core 2 Duo" 2.5 (08)2.5 GHz Core 2 Duo (T9300)
- MacBook Pro 17" "Core 2 Duo" 2.6 (08)2.6 GHz Core 2 Duo (T9500)
Therefore, you might be able to update your MacBook by following LowEndMac.com’s tutorial even though your MacBook is not “Unofficially” included.
macOS Sierra on Low End Macs
I hope this revised answer was helpful
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
