Zum Hauptinhalt wechseln
Apples Laptop-Serie für Nutzer:innen mit höheren Ansprüchen im beruflichen oder privaten Gebrauch. Bislang gibt es Modelle in den Größen 13, 14, 15, 16 und 17 Zoll. Die wichtigsten Entwicklungen gab es beim Prä-Unibody (Original), Unibody, Retina Display, Touchbar und SOC (system-on-a-chip) Design.
20001 Fragen Alle anzeigen
Random MacBook Pro shut down after replacing with ifixit battery
Since replacing the battery in my mid-2012 MacBook Pro with an ifixit.com replacement battery, it now shuts down randomly.
I’ve heard about a firmware update that could resolve this but don’t know the exact details.
Can someone share how to fix this?
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
Which system? The unibody or the retina? The 13" or the 15"?
von
Einen Kommentar hinzufügen
2 Antworten
Try updating the firmware. See if that works. If that doesn't work then try cleaning the battery contacts with some alcohol and a toothbrush (carefully). If that also doesn't work then it might be that you got a bad battery. If that's the case, then contact iFixit for a replacement battery.
War diese Antwort hilfreich?
Bewertung 0
I would check the CMOS battery first before blaming the main battery. This battery will cause a computer to shutdown randomly or not startup at all. I've had several computers with that problem, laptop and PC. Its an inexpensive fix and fairly easy to check on most laptops though some can be moderately difficult to get to.
Hope this helps.
Eddie
Bewertung 0
2 Kommentare:
@towerjack1960 - No CMOS battery in any of the MacBook Pro systems.
von
@danj. Thank you for letting me know that. I didn't realize that. I know windows has them because I get the batteries out of junk cases each week. Haven't had a MacBook Pro in awhile, think I have one around here somewhere. What do they use for BIOS then?
von
Antwort hinzufügen
robotman123 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 130
