Zum Hauptinhalt wechseln
Model A1224 / Mitte 2007 und Anfang 2008 / 2, 2.4, oder 2.66 GHz Core 2 Duo Prozessor
548 Fragen Alle anzeigen
iMac 8.1 Screen is oversaturated also on external monitor
I got my hands on an old Imac 8.1.
The screen in standard mode is however oversaturated. I get the same result when I connect een external monitor. I was able to get it a little bit better readable screen with calibration, attached 5 pictures.
2 with the oversaturated screen
2 with the same screens now corrected a bit.
1 from my Imac 14.2 with the same backgrounds to show the difference.
Are there options to tune the graphics card or should I look for a replacement of the graphics card?
The OS is Snow Leopard
Thanks and regards,
Jacob
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
First, go into System Preferences, then Displays, then click Color. You should have a lot of options listed. Click on the top one that says Color LCD. You should see the colors change. Hope this helps.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thank you for your answer. I already did that as you can see in the picture 1 & 2. The top option (and other standars) give the over saturated view. As stated I created a calibrated one, which gives a slightly better display but still over saturated view, see picture 3 & 4.
von
@sjakio it might be the graphics card is defective or glitchy so you might want to look into gpu replacements.
von
Antwort hinzufügen
jacobkamminga wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 88
