Zum Hauptinhalt wechseln
Eighth generation of the Honda Civic.
20 Fragen Alle anzeigen
Where is Bluetooth module located in Honda Civic 2010?
I have a Honda Civic 2010 EX-L with Navigation and Bluetooth. I’m replacing the factory radio with an aftermarket stereo and need to locate the Bluetooth (aka Honda Handsfree Link or HFL) module to make wire connections. I already looked under the dash and steering wheel but no luck. Thank you in advance for your help!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would imagine it’s part of the factory head unit
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
My understanding is that it looks like this: https://i.ebayimg.com/images/g/DRIAAOSwT.... I need to T-tap into one of the wires on the green connector that plugs into the module, to keep my handsfree calling feature control on my steering wheel. Thanks.
von
@gosaigo
@hootonberg may be correct.
It's not shown anywhere in the service manual not in the component location section or even in the wiring diagrams or not that I could find anyway.
von
@jayeff Thank you for taking the time to check the service manual. It’s probably part of the head unit that I replaced, as @hootonberg said. When I contacted iDatalink Maestro, they led me to believe that it’s a separate module located somewhere under the dash on the driver’s side. I could not find it after taking off all the covers On the driver’s side. I decided to skip the steering wheel controls on Bluetooth. Thank you both!
von
Antwort hinzufügen
Sai wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 1,091
