Zum Hauptinhalt wechseln
Die MacBook Familie entstand im Jahr 2006 und ersetzte das iBook als Consumer Laptop.
3787 Fragen Alle anzeigen
My MacBook keyboard stopped working.. how can I fix it?
days ago, my 13" macbook started having problems. first, the highlights on a folder wouldn't go away, no matter what other folders i clicked. whenever i needed to preview pictures from a folder, it would always show the bottom half of the contents. when i had to shut down, the laptop would make these ding sounds continuously. when i tried logging in to my email account, it would show one letter filling the username field on and on. and now, the keyboard doesn't work at all.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
You have a key stuck down and it is continuously entering itself. Pull the keycap off the one thats entering and see if you cam clean it and get it to stop. Try using a Q-tip dipped in alcohol. If this fails you will probably have to replace the keyboard.
War diese Antwort hilfreich?
Bewertung 4
i tried an external usb keyboard and it works. for now. but the laptop's keyboard won't work at all. is this a logic board issue?
Bewertung 0
m y macbook A1181 keyboard is not working after startup the caps light is on and only few keys are typing but double strikes.
any solution do have thanks
i had open the motherboard but there is no battery on board
Bewertung 0
Antwort hinzufügen
Joel Sol Cruz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 2,108
