Zum Hauptinhalt wechseln
The Lenovo IdeaPad Flex 5-1470, manufactured in 2017, features a 14 inch touch screen display which folds 360 degrees into a 2-in-1 convertible laptop. Model Name: 80XA Model Number: 80XA0001US
4 Fragen Alle anzeigen
I spilled water on my laptop
i spilled a soup on my laptop and i put it upside down for 20 minutes and open it and it wont turn on, i went to a technician and asked it to be fix. it will open but when you shut it down it will not open again so the techinician would repair it again and it will be okay but when he shut it down it will not opem again, what is the possible problem for this?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
The water causes corrosion and provides circuit paths for the electricity which were not in the laptop’s operating design and could damage the components. The corrosion starts immediately and doesn’t stop until it has been properly cleaned away.
Do not try to charge or to turn on the laptop and then remove the battery as soon as possible so as to minimize any further problems.
Next you need to disassemble the rest of the laptop and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the concentration (%) of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb, be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Also remove any shields that may be covering some components and clean there as the water may have got in under them as well. The ends of any cables and the connectors need to be cleaned as well.
Hopefully after you have done all this the laptop might possibly work correctly again.
Here is a link to the hardware maintenance manual that may help at least with opening the laptop so that you can check what damage may have already occurred.
If this process seems too daunting, I suggest that take your laptop to a reputable, professional laptop repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later. It isn’t going to fix itself.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
i brought it to a technician already and it will open but when turned off again it will not open and needed to repair again before it will open
von
@CGot7
I think that the technician may have missed something. It needs it be working correctly more than once before it leaves the workshop.
Take it back and show the technician what is happening.
Most reputable repairers give some sort of guarantee on their workmanship (even if it is only 30 days).
You may have to try someone else if they can't fix it.
With liquid damage the laptop has to be thoroughly checked all over (basically completely disassembled) to make sure that the water hasn't penetrated in places that aren't immediately obvious and corrosion is occurring there. If it is not checked and cleaned properly, problems can arise days, weeks even months later. The fact that it happens as soon as you get it back from the technician is not good.
von
Antwort hinzufügen
CGot7 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 7
Letzten 30 Tage: 45
Insgesamt: 1,096
