Where is the oil drain
Where is the oil drain on my Briggs & Stratton motor 158cc 5.50
Ist dies eine gute Frage?
Some engines will have an oil drain plug located on the bottom that looks like this:
But, some oil drain plugs will be covered by the housing, in which case, even the manufacturer says you can tip the engine over and drain it out of the fill tube.
War diese Antwort hilfreich?
Seize tool for oil drain plug
@azharmdidris make and model for your engine?
Letzte 24 Stunden: 0
Letzte 7 Tage: 23
Letzte 30 Tage: 65
Insgesamt: 390
Edward Bois we will need an engine number or model number for this.
von oldturkey03
