Zum Hauptinhalt wechseln
Veröffentlicht im Juni 2009 / 2.66, 2.8 oder 3.06 GHz Core 2 Duo Prozessor
300 Fragen Alle anzeigen
White Screen at Startup
Everything worked fine before, but needed a new battery. Bought the new battery from Ifixit, replaced it, then booted it back up and now I get a white screen at startup. Tried to start in safe mode and still won’t get off of the white screen. Like I said it worked perfectly fine, before the battery swap. Any help would be great.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
A white screen is usually an issue with the hard drive. Check your hard drive cable to logic board connection.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
It does sound like my hard drive is having an issue. Keeps making like a whineding up sound
von
Looks like everything is connected
von
connect to external display if it still on white screen press command and r and press the power button the enter recovery mode
Bewertung 0
1 Kommentar:
Just tried and it won’t connect to the external display nor did it take the CMD, R, power button
von
Antwort hinzufügen
Tyler Hockaday wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 62
