Zum Hauptinhalt wechseln
Herausgekommen am December 3, 1994 in Japan und am September 9, 1995 in Nordamerika. Modelle SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, und SCPH-900x.
73 Fragen Alle anzeigen
Accidentally tore off optical drive power supply cable socket
While doing repairs I realized I had torn off the optical drive power supply cable socket from the motherboard. That's the white plastic thing with the metal parts. The metal pins are intact. Should I solder then back on? If so, do you have any tips?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
@voidemissary post some good pictures with your QUESTION showing what the damage looks like.
Bilder zu einer vorhandenen Frage hinzufügen
von
Einen Kommentar hinzufügen
1 Antwort
I can’t see if the solder pads on the board are damaged or not, from the look of the pins you should be fine.
It won’t be a difficult job but always practise first if you aren’t sure of your abilities. Use a small amount of solder to help reflow the existing solder on the pins.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Should I add solder to the pins or the board? And should I add solder to the sides of the plastic socket where the broken off metal is?
von
Sorry, haven't logged in in a while.
Small amount of solder to everything I think, but just enough to leave a very small coat. Solder the metal at the sides, that could be an earth connection.
von
Antwort hinzufügen
Egg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 51
