Zum Hauptinhalt wechseln
Released 2013, identified by model number PS 5530. All-in one printer, scanner, and copier. Also has web and wireless properties.
Power AC Adapter search
Hello all…Please can someone tell me where do i buy the AC power Adapter that is shown in your repair videos for the HP 5530-e all in one showing that the Ac Adapter can be removed from under the left hand side of the printer casing , and to change when it’s not working ?..look forward to your replies .
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @ericthevike66,
Not sure if it is the same for a HP Envy 5530e but looking at this image in the ifixit HP ENVY 5530 Power Supply Replacement guide, the model number for the power supply is A9T80-60008.
(click on image to enlarge for better viewing)
When searching online using the model number only, there are results for suppliers. Here is just one to give you an idea of the cost.
If the model number of the power supply is different for your particular model then search online using its’ model number to hopefully find suppliers that suit you.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hello Jayeff…thanking you so much..have used the info to order my Power AC..Thanks a million.
von
Antwort hinzufügen
Eric Fielding wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 156
