Zum Hauptinhalt wechseln
{A1706 / EMC 3071}—Veröffentlicht im Juni 2017. Dieses 13" Macbook Pro ist mit Kaby Lake Prozessoren bis zu 3,5 GHz Core i7 mit Turbo Boot bis zu 4,0 GHz ausgestattet.
276 Fragen Alle anzeigen
CNW001 No Wifi hardware after screen replacement
Hello! First post here, wondering if anybody has any ideas…
I replaced the lcd screen assembly on my macbook pro, was not my first time doing and went well except when I powered on my mac i was unable to see any wifi networks. While trouble shooting i deleted the Wifi interface, which I still cant get back, but nothing seemed to work.
I decided to open back the mac and found one of the wifi/ airport adapter connectors was broken. I ordered a new part and put it in. Everything seems to be connected fine but still no fix. Reset PRAM, SCM and hardware diagnostic still shows code CNW001.
Any help is greatly appreciated!
P.S. When opening mac all the way there is a click noise. I imagine the wifi antena may not be seated correctly even tho everything is connected but anyone had this problem ?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Did you follow this guide? MacBook Pro (13 Zoll, Ende 2016, Touch Bar) Displayeinheit austauschen ?
I'm suspecting you damaged the antenna plate (seen in Steps 25 & 26) or your WiFi/BT logic on the logic board is damaged.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Connor Thomas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 231
