Zum Hauptinhalt wechseln
Das März 2015 Update von Apples 13" MacBook Pro Retina Display, Modell A1502, bietet fifth-generation Intel Core i5 und i7 Prozessoren der 5. Generation und führt den Force Touch Trackpad ein.
1185 Fragen Alle anzeigen
MacBook SERVICE BATTERY status and where is it stored?
I know for a fact that Service Battery status is stored in OSX files somewhere but not sure where??
  • Reinstalling Macbook removes this status.
  • Running Macbook from external OSX removes this status.
  • Reinstalling OSX and migrating original OSX removes the status.
Id like to know where is this status hidden in OSX files to remove it without reinstalling??
Anyone has any idea where to look for it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The OS does not hold the setting! What you encountered is when the OS install process ran it cleared the setting held in the SMC EEROM area after SMC has read off the battery cycle count and/or when the voltage sensor drops below a set threshold.
You can see the see your batteries status using CoconutBattery take a snapshot of the apps main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen
It does sound like you need to replace your battery MacBook Pro 13" Retina Display Anfang 2015 Akku austauschen
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
MacBook Pro 13" Retina Display Early 2015 Akku Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
45 minutes - 2 hours
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
Not sure if you are correct. I can start this Macbook using other USB boot drive with different OSX and status is gone. No installation there and NO SMC reset done.
It feels to me like the setting is stored in OSX somewhere and not in SMC or battery.
Also 3 days ago I reinstalled customers Macbook with Service Battery status. Status was gone on clean osx and after migrating the data. I am doing full battery cycles for 3 days and status is not comming back.
von
@windcatcher - How to reset SMC How to reset the SMC of your Mac Note "the can resolve certain issues related to power, battery, fans, and other features." Does that help you explain why this is not software but a hardware level issue.
How about running CoconutBattery and posting a snapshot to prove me wrong ;-}
von
@danj
Ressetting SMC, resseting PRAM or unplugging battery never fix this status nowadays.
Starting with different USB boot drive or fresh install always fix this status and that is why I suspect some flag in OSX files and not only SMC EEROM.
I repair Macs and have many of them every day.
Some of it are used on a charger all the time and get service battery status. In most cases battery is still fine ...
What I need is fast way of removing this status and then instructing the user to properly charge &discharge it every few days.
von
@windcatcher - Without seeing CoconutBattery screenshot you are not telling me anything useful to figure out what's wrong. Just because your symptoms go away magically is useless info.
Using sound engineering processes and diagnostics is the only way we can move forward here.
von
Antwort hinzufügen
Windcatcher wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 85
