Hi,
The short answer is yes to the ram and SSD but no to the M.2 SSD
You can install up to 16GB (2 x 8GB) of DDR3L 1600 PC3-12800 SODIMM ram.
You can install a 2.5” sata SSD in a caddy (supplier example only) to increase the storage, but you will have to lose the ODD (optical disc drive) to do this. Also if you install a sata 3 SSD it will only operate at sata 1 speeds because this is the speed of the ODD sata port. The HDD port is sata 3
Here’s the hardware maintenance manual for the laptop.
Go to p.36 to view the necessary pre-requisite steps and then the procedure to remove the optical drive.
Go to p.41 to view the necessary pre-requisite steps and then the procedure to remove/replace the memory
Here’ s a link to a supplier of ram and SSD compatible with the laptop. It is only shown to give an idea of the cost and what options there are.
There is no M.2 slot in the laptop.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
