Looking for the definitive answer on upgrading my Mac
Hi folks, having analysis paralysis after reading too many conflicting and dated articles so hoping to get a current and definitive view before I jack up my iMac.
Current state of play: mid-2017 iMac 3.4GHz 4k 8 GB RAM w/ 1TB Fusion Drive running Catalina. It is far too slow for its age, so planning to upgrade a variety of components in one fell swoop including:
1. Replace 24 GB SSD Blade w/ new OWC 240 GB
2. Replace 1TB SATA HD w/ new OWC 1TB SSD
3. Replace 8GB RAM w/ 2x 16GB
4. Clean install of Big Sur
Plan as I understand it is:
a. BACKUP
b. Split the existing Fusion drive set even though both the SSD blade and 1TB HD will be replaced
c. Open her up and replace all components. Hold breath.
d. Boot in Internet Recovery mode or USB to install Big Sur to the SSD Blade.
Where I’m unsure:
- Anything I need to do to make the Mac use the 1TB SSD for my main data storage? This includes my home folder and iCloud syncing.
- Is there a simpler way? This may be overkill but I only want to open it up once since it’s bit of a pain.
Update (11/28/2020)
Follow up progress and another question please….
Good news is the hardware and Big Sur clean install all were uneventful and the system now feels super responsive (as I’d expect with hardest anything on it of course).
I have my SATA SSD setup now too and can login as either the admin (home folder on the blade) or my regular user account (home folder on the SATA SSD).
Question I’ve got now before getting too far restoring data… is it still possible to encrypt the SATA SSD using FileVault or similar, such that drive contents are encrypted but I can still login at boot up in a straight forward way. It seems FileVault only supports the boot volume, and if I encrypt the SATA using DiskUtility I fear it will not be available at boot up.
Is there a simple way through this? Potentially I could recreate the Fusion set combining the 2 SSDs but understand that is a bad idea from performance POV.
Thanks much
Ist dies eine gute Frage?
