Zum Hauptinhalt wechseln
Repair guides and support for your Philips TV.
243 Fragen Alle anzeigen
Philips 50pft6550 backlight faulty
Hi,
I turned on the TV and the picture was black but the sound was ok, therefore I did the light test and I could see that the panel is ok.
I have tested the backlight on the power board and I got 75V on Led1 and 75V on Led2, both on stand by and tv on.
I can't find the datasheet of the power board(photo attached)
Is there any way of getting the data sheet?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@essh19 the voltages from your power board sound about right. Check the backlight strips since they have a tendency of failing. Backlight strips are the same as for a Vizio D50-D1. Part number for the strips should be YX-50024011-4E761-0-B-63M -53285
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Elad s wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 172
