PCI LAN: Realtek PXE B09 D00
I have a pop-up on my daughter's laptop has this error that pops up and we can't get it off.
Ist dies eine gute Frage?
Check if you see a hard drive present in the BIOS - LAN boot (which is what this Realek PXE message you’re seeing is). PXE boot is a common sign of a bad hard drive or bad OS, but often a bad drive. If you see the hard drive, run Hiren’s Boot CD to see if the drive is present and reading data reliably. Once confirmed to be good, run a SMART test and do a self-test to make sure it isn't bad.
If the drive has detection issues, do not mess with it if you need her laptop to work - replace it.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 27
Insgesamt: 4,048
