Zum Hauptinhalt wechseln
Die kleinere Version des iPad Pro, herausgekommen am 31. März 2016. Ausgestattet mit einem 9,7" Display, dem A9X Prozessor und wahlweise mit 32/128/256 GB Speicher. Erhältlich in Silber, Grau (Space Grey), Gold und Rose Gold.
Repairing an old iPad
I fiddled with repairing my old 9.7” IPad Pro a while back when the thing no longer would turn on or charge. During the repair I replaced the battery and the screen. I had a hard time getting the battery out and now the new battery is damaged. My question is will the iPad run on a lightning connector only? Or does it require an actually connected battery? Tryin to figure out if I blew the logic board in it or not
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
hello Fxguy1,
unfortunately, repairing iPad, contrary to appearances, is neither easy nor safe for it. Originally simple problems are extended by careless technicians to the limits of profitability of repair. Most damage occurs at the stage of removing the motherboard - this is after attempts at unauthorized repairs. Currently, there are no documentation and diagrams of modern iPads in the public space, so the amount and quality of knowledge on this subject is quite limited. However, this does not prevent a few people with experience and knowledge of microelectronics freely navigating the topic with amazing efficiency. To answer your question: yes, a start-up voltage is required to run iPad pro 9.7, via the main power manager (PMU) - colloquially speaking: a battery is required to start the iPad. Powering iPad through the lighting port is one of many option, but other conditions are still required, including connected power through the battery port, in the PMU environment. It sounds confusing to people with little knowledge of iPad repairs, but it's really not difficult. Simply put - knowledge about it is essential. My advice is to take your iPad to a good repair shop. If you can solder microelectronics, ask for a diagnosis. On its basis, you will be able to continue your adventure with iPad repair - which I urge you to do.
  • regards,
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Fxguy1 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 124
