Speed only works on highest setting on the dial
Hi my Kenwood mixer will only work at the fasted setting on the dial
Update (12/18/2020)
- On the fastest setting on the dial
Ist dies eine gute Frage?
@freddifrog this is most likely caused by a failed spark suppression capacitor for the governor. IF it fails your mixer will only work at full speed. Check for it under the cover on the bottom of the motor. You’d be looking for a small, round, aluminum can looking part. Post some images of what you find so we can assist you further with that.
Here is Untitled the service manual to help you with your disassembly etc.
War diese Antwort hilfreich?
there are two aluminum can looking parts but how do I know which one works and how can I replace it and where can I get the part?
There's sure to be a label on it. Post a photo here, we will help. Replace both, they're cheap. You can usually get them through an mail order company for electronics.
I had the problem on kcc9060. I changed the dial element (so the triac) and i solved the problem.
The problem returned its not the dial maybe the motore rotation sensor
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 756
9 Kommentare
Can't find an option to add a photo
von P Greenwood
@freddifrog here is the guide for it. Bilder zu einer vorhandenen Frage hinzufügen You'll have to edit your QUESTION and add those images to it.
von oldturkey03
Thanks. Just having a look.at it now
von P Greenwood
Apparently I need a part
von P Greenwood
I need a part BTA208-600B
von P Greenwood
4 weitere Kommentare anzeigen
