Zum Hauptinhalt wechseln
Third generation of the Fitbit Charge fitness tracker series.
20 Fragen Alle anzeigen
Fitbit Charge 3 charging pinout?
I was looking for the pinout earlier and nobody on the internet had the answer...
I ended up buying a charger clip and promised myself to post the pinout to help anyone who needs to charge it without the clip.
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
From left to right:
  • +5V
  • not in use
  • GND
War diese Antwort hilfreich?
Bewertung 8
3 Kommentare:
Appears that this info is also correct for the Fitbit Charge 4 as well.
von
I brought Fitbit charge 3 band for less than $1 at scrap store. Thank you for the information, i needed it finally, now I will hack into it
And add new battery and charge without the clip...
von
Also worked on a Fitbit Inspire 2, which looks similar on the underside. 5V (red) on the left contact, GND (black) on the right, when oriented like the photo.
von
Antwort hinzufügen
io nut wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 41
Insgesamt: 3,639
