Zum Hauptinhalt wechseln
Dritte Generation der Fitbit Charge Fitness-Tracker-Serie.
Fitbit Charge 3 charging pinout?
I was looking for the pinout earlier and nobody on the internet had the answer...
I ended up buying a charger clip and promised myself to post the pinout to help anyone who needs to charge it without the clip.
Ist dies eine gute Frage?
Bewertung 5
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
From left to right:
  • +5V
  • not in use
  • GND
War diese Antwort hilfreich?
Bewertung 10
5 Kommentare:
Appears that this info is also correct for the Fitbit Charge 4 as well.
von Teilen
I brought Fitbit charge 3 band for less than $1 at scrap store. Thank you for the information, i needed it finally, now I will hack into it
And add new battery and charge without the clip...
von Teilen
Also worked on a Fitbit Inspire 2, which looks similar on the underside. 5V (red) on the left contact, GND (black) on the right, when oriented like the photo.
von Teilen
YES! Wonderful, thank you so much. I taped carefully stripped USB-cables +5V and GROUND and it's charged from 7% to 56% now. Can't thank you enough. Charging my Fitbit Charge 3 right now. Saved me a three hour ride!
I've been using this Fitbit Charge 3 for so long now the display stopped working a year ago. Still tracks good though.
von Teilen
Can confirm this pic applies to Fitbit inspire 3 (orientated that was up it goes +5v, something, something, ground) so I connected my positive wire to the left and negative wire to the right.
I am surprised that, with a 1 amp charger, I was able to get it from dead to about 30 percent with only about 2 minutes of contact total (very fiddly, kept disconnecting and so this was the result of about 20x 6 second bursts, just keep retrying). Lasted the night anyway so got to record my sleep albeit this endeavour had me up until 6am so it was probably not wise.
von Teilen
Antwort hinzufügen
io nut wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 22
Letzte 30 Tage: 125
Insgesamt: 5,145
