Zum Hauptinhalt wechseln
Modell A1369, 1.6, 1.7, oder 1.8 GHz Prozessor, 64, 128 oder 256 GB Flash Speicher.
Power Button without function
My Mac Book Air (2013) has a broken Power Button. There‘s no function if I try to turn it on or off with Power Button. But if I disconnect my battery and connect it again, it‘ll turning on. So is this a keyboard issue and will be solved with a new one? Can it be caused to my battery? Or is there another potential reason?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It does sound like you narrowed down the issue. There is a set of contacts (power pads) on the logic board which if you short across them for a moment your should also power on.
If they do then you’ll need a new uppercase (which is the easier fix) or you need to replace the keyboard its self (much harder) for either you’ll need to follow this guide: MacBook Air 11" Mitte 2011 oberes Gehäuse austauschen Finding the upper case part will take a bit of hunting as they are no longer being made look for Apple P/N 661-6072
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thank you very much!
Actually I‘m new to MacBook stuff (did iPhones a lot and feel safe with some MacBook repair tasks)... Hut can you explain me, how to „short across contacts“? May this is a language problem (I‘m from Germany and my English is kinda rusty), but I don‘t get it... Sorry about this.
von
@doenerkater - I use a flat bladed screwdriver. It just takes a quick hit. Think of it like a switch which shorts across the two wires to turn the light on.
von
Awesome, thank you so much.
von
Antwort hinzufügen
Katrin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 354
