Zum Hauptinhalt wechseln
Modell A1369, 1.6, 1.7, oder 1.8 GHz Prozessor, 64, 128 oder 256 GB Flash Speicher.
328 Fragen Alle anzeigen
Power Button without function
My Mac Book Air (2013) has a broken Power Button. There‘s no function if I try to turn it on or off with Power Button. But if I disconnect my battery and connect it again, it‘ll turning on. So is this a keyboard issue and will be solved with a new one? Can it be caused to my battery? Or is there another potential reason?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It does sound like you narrowed down the issue. There is a set of contacts (power pads) on the logic board which if you short across them for a moment your should also power on.
If they do then you’ll need a new uppercase (which is the easier fix) or you need to replace the keyboard its self (much harder) for either you’ll need to follow this guide: MacBook Air 11" Mitte 2011 oberes Gehäuse austauschen Finding the upper case part will take a bit of hunting as they are no longer being made look for Apple P/N 661-6072
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thank you very much!
Actually I‘m new to MacBook stuff (did iPhones a lot and feel safe with some MacBook repair tasks)... Hut can you explain me, how to „short across contacts“? May this is a language problem (I‘m from Germany and my English is kinda rusty), but I don‘t get it... Sorry about this.
von
@doenerkater - I use a flat bladed screwdriver. It just takes a quick hit. Think of it like a switch which shorts across the two wires to turn the light on.
von
Awesome, thank you so much.
von
Antwort hinzufügen
Katrin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 197
