My HP 840 turns on but after 1-2 seconds turns off.
My HP 840 turns on with the HP logo and Bios but after 1-2 seconds turns off.
Not reacting on any buttons combinations. Turns on only if I connect the power adapter.
Tried to change the battery but not helped.
Please help.
Ist dies eine gute Frage?
9 Kommentare
So it works if the battery is disconnected and just the power adapter connected, is that correct?
von mike
@aactech No, it not.
von Ilya Liberman
@Ilya Liberman
So it is probably a mother board issue. Something is overheating quite quickly. Here is the url for the HP service manual:
https://support.hp.com/nz-en/product/hp-...
One other thing. Have you tried resetting the BIOS?
HP Elitebook 840 G1 Hauptplatine austauschen
Unplug the charger and disconnect main battery.
Look at Step 2. The CMOS battery is encased in yellow. Just disconnect its connector by sliding it up and off. Press your power button for about 15 seconds to discharge any power in the system.
Reconnect the CMOS "coin" battery, plug in charger and see if it turns and stays on.
Let us know how it goes.
von mike
@aactech I did a CMOS reset but it not helped me.
von Ilya Liberman
@Ilya Liberman
Always disconnect power and remove the battery before doing anything inside. Next I would take out, one at a time, the hard drive and Wi-Fi card, to see if they are defective and causing the shutdown problem. If that doesn't fix your problem then try removing the RAM and reinserting. If two RAM modules try one and then the other.
von mike
4 weitere Kommentare anzeigen
