Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2011 / 2.5 & 2.7 GHz Core i5 oder 2.8 GHz Core i7 Prozessor
432 Fragen Alle anzeigen
2011 21.5" iMac No Backlight
Hey guys!
So I have a 2011 21.5” imac I've been working on, and I cannot get the backlight working at all. I've been through 3 different LED driver boards, and even tested 3 different powersuppies. If I aim a light on the display at the right angle, I can see the apple folder flashing. Any other ideas on what the issue could be? Bad LCD?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I would focus on the cables and the connectors. How about taking some good clear tight shots of the cable ends and the connectors on the logic board side and the display side so we can see what they look like Bilder zu einer vorhandenen Frage hinzufügen
Refer to this guide iMac Intel 21.5" EMC 2428 Display Austausch Steps 5, 6, 7 &8
Update (01/30/2021)
@Corbin Titus - Still not sure, but lets assume the cables and connections are OK. Then we need to assume the issue is within the logic board backlight power circuit.
Using a DVM and a boardview drawing test the three MOSFET’s I’ve shown you here. IF this is beyond your skill set you’ll need to find someone locally to help you.
iMac Intel 21.5" EMC 2428 Display Bild
Anleitung
Schwierigkeitsgrad:
Mittel
30 minutes - 1 hour
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
War diese Antwort hilfreich?
Bewertung 0
12 Kommentare:
Added images
von
@Corbin Titus - Can you redo the display cable connection on the logic board your image is too blurred.
von
Added anither one
von
Hey, I saw what you added to your post, and I had a few more questions, the logic board I'm using is actually a replacement one that was supposedly tested and working, is there anything else it could possibly be? Is there a way to test the backlights on the display manually?
I can also test the MOSFETs
Edit: also, the fans run at 100%, which leads me to believe that the motherboard isn't able to detect / pickup the temperature sensor on the LCD maybe? (I have everything else plugged in)
von
Also, the LCD temp sensor and the vsync cable are connected together, is it possible the cable / temp sensor is bad, causing the LCD not to light up and cause my fans to ramp up?
von
7 weitere Kommentare anzeigen
Antwort hinzufügen
Corbin Titus wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 203
