Zum Hauptinhalt wechseln
Der Acer Nitro 5 AN515-53-55G9 ist ein Laptop für preisbewusste Gamer, welche 2018 auf den Markt kam. Der Laptop verfügt über einen 256 GB SSD Speicher, eine Nvidia GeForce Grafikkarte und einen Intel Core i5 Quad-Core Prozessor zu einem günstigeren Preis als bei den meisten Gaming Laptops.
60 Fragen Alle anzeigen
My laptop is stuck in an install loop.
My laptop has been running pretty slow for quite a few months but its brand new, so i decided i would try doing a restore to my last backup (which i created when i first got the laptop) in case i might have downloaded something that was causing this performance hit. i then realised my backup had disappeared so i did a reinstall of windows to factory settings, it did its normal windows install loop that took about 2-3 hours but then it just kept looping constantly turning itself on and off but keeps saying windows is installing at 64%, so i left it for another 3 hours thinking it was just taking longer than it should.
3 hours later. it was still in the same install loop, but now only 1 in every 5 reboots it would say how much of windows is installed and still say 64%. now i knew there was an issue, i have a windows 10 media tool USB and tried plugging that in and let it run for about 20 minutes hoping one of the boot loops it would go to the USB instead but nothing happened, it just kept looping.
anyone have any reasons for why my laptop is deciding to be in a boot loop with installing windows?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi,
Did it actually boot from the Win 10 media USB when you inserted it and restarted the laptop and not just from the HDD again?
Just verifying that you altered the boot priority and also changed BIOS settings so that it would boot from the USB.
The user manual for your model doesn't show the BIOS settings but usually it is either Legacy USB or CSM has to be enabled for it to boot from a USB.
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
I changed the BIOS multiple times to read the USB, it still read the HDD first. i managed to fix the issue just 10 minutes ago by reinstalling the media tool to the USB and plugging it into the laptop, loading the BIOS and forcing a load from USB, the laptop is back to working and fixed but i still have no idea why the windows went into a boot loop while installing
von
Also the BIOS it uses is UFEI not legacy as the model of my Acer Nitro doesnt show up in the ifixit list but it was close enough
von
@GeekSheekNerd
Most newer laptop's BIOS these days have UEFI but there usually is an option in BIOS to go to a legacy mode just so you can boot from a USB.
Did you look through all the settings, maybe check under either the boot menu or the security menu tab.
As I said the user manual I looked at for Acer an515-53 models didn't show anything about the menu settings in BIOS
von
von
Antwort hinzufügen
GeekSheekNerd wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 523
