Zum Hauptinhalt wechseln
Model A1347 mit 2.4 GHz oder 2.66 GHz Intel Core 2 Duo CPU
mac mini 2010 High Sierra Handoff or Airdrop activate
Hello guys
I want to use handoff or airdrop in my mac mini, do I need a new airport card?
If necessary, please provide us with a compatible list.
I've already tried Bluetooth dongle, but it's not activated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Sadly, its just not possible to upgrade your AirPort. There are two aspects the hardware connection is very different between your system and the needed AirPort board and the OS level you require for your system won’t support it.
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
So I can't use handoff in my Mac?
von
Sadly no. Apple altered things enough to prevent it.
von
ok... :/ thank for answer
von
Hey, I used a beta version of the Continuity Activation Tool and it was activated
von
@ajsa124 - Did you read up before you used it?? How to get Continuity on an unsupported Mac
One of the biggest risks these days is RAT and Malware which your system was protected, using the tool puts your system ore at risk. I don't recommend using this tool instead if your system can support the newer AirPort board I would go that way. Sadly your system doesn't offer that as an option.
von
Antwort hinzufügen
TS Ryu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 399
