Zum Hauptinhalt wechseln
Apples Smartwatch der dritten Generation mit optionaler Mobilfunkverbindung, veröffentlicht am 22. September 2017
197 Fragen Alle anzeigen
What do I do with Adhesive Gasket
I have an apple watch 3 series I’m not sure what to do with this piece { Series 3 GPS) Force Touch Sensor Adhesive Gasket } I replaced my screen and the seal and it works great , but my screen is a little loose on one side .Is this what this piece is for ? What would it do to the seal if I had to take the screen off again ?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
This question was migrated from https://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
1 Antwort
Previous versions of the Apple Watch (including the 3 had a feature called force touch, where pressing on the screen with light force would show extra options. If you need that functionality (which you probably do) you will have to open the screen back up, which will most likely break the seal. You should follow this guide, as well as the guide linked at the bottom of the page in the Conclusion section.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Patricia Dickerson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 60
