Zum Hauptinhalt wechseln
iMac Intel 27" EMC 2309 (Ende 2009, Core 2 Duo 3.06 oder 3.33 GHz) ID iMac10,1, EMC 2374 (Ende 2009, Core i5 2.66 GHz oder Core i7 2.8 GHz) ID iMac11,1
467 Fragen Alle anzeigen
CCFL bad on left side, boots on Safe Mode but not standard
Trying to save this one for a kid. Even with the CCFL out it is usable. Plulled the HD (it had been upgraded to 2TB), wiped the drive and installed a clean system of El Capitan on a MacPro. The Pro (2008) runs fine using the drive as an external,
Booting iMac from an external enclosure, Machine boots fine in Safe Mode but not standard mode. (I get a multicolored dotted display with a black box. Does anyone know what to pull out of the library to get it not to check the display so it can be used again.
@danj
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
@mayer - What is the HDD make and model?
von
@danj Seagate 3.5" 2000 GB Model ST2000DM001
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I think your facing a SATA I/O issue here the ST2000DM001 is a SATA III (6.0 Gb/s) drive, this system only offers a SATA II (3.0 Gb/s) interface. Depending on which version you will have either a ATI Radeon HD 4670 or Radeon HD 4850 GPU, but when you are running in Safe Mode this series uses the Intel EFI driver in compatibility mode. with is why it works in safe mode.
Try a known SATA II drive to see what it does.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
@danj That was a good idea, so I set up El Capitan on a 3 Gb/s drive but got the same results. Failure to fully boot in full mode but just fine in Safe Mode. I'm thinking it has to do with the video drivers. Any ideas?
von
@mayer - What happens when you reformat and install Yosemite on the drive. I just can't see this as a driver issue. More likely a bad GPU board.
von
Antwort hinzufügen
mayer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 56
