Zum Hauptinhalt wechseln
Reparaturanleitungen und Informationen zur Demontage von Laptops und Notebooks aller Formen, Größen und Farben.
18857 Fragen Alle anzeigen
Toshiba Satellite A660 stuck at a blank screen
when I turn on the laptop, it passes the toshiba logo screen and brings a black screen with a flashing white underscore on top_left. then the flashing stop and it freezes for ever.
it happens also if I try to boot with a usb.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Could be the hard drive but try this first:
  • Shut down, unplug the AC adapter/power supply/charger and remove battery.
  • Press and hold power button for 20 seconds.
  • Connect charger and press power button. What happens?
  • You could also try taking out and reseating the RAM.
  • Are you able to get into the BIOS?
Here’s a video on disassembling:
https://www.youtube.com/watch?v=BaUEb_Oi...
Here’s a link to the service manual:
https://www.manualslib.com/manual/436220...
Here’s a link to the user manual:
https://support.dynabook.com/support/mod...
Note: Toshiba is now owned by Dynabook.
Hope this helps. Let us know how it goes.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
So the problem was somehow from the hard disk. I took it out and put it in another laptop where it worked again. I moved to different operation systems in it and then when I returned the hard disk to the original laptop, it could boot again. One can also run recovery modes in the other laptop for the hard disk.
Bewertung 1
Hope you can find a solution from the post and video tutorial below:
https://www.minitool.com/data-recovery/w...
https://www.youtube.com/watch?v=2b6xCwZP...
Bewertung 0
Antwort hinzufügen
alireSa Ranjbar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 106
