Zum Hauptinhalt wechseln
Die Neuauflage von Apples iPad Air Tablet vom März 2019, das mit dem A12 Bionic Prozessor und dem 10,5" Display antritt.
39 Fragen Alle anzeigen
iPad Air 3 touch screen section not working after replacement.
I replaced the display on my iPad Air 3 with the i fixit screen, but for some reason there is about an inch wide streak down the middle of the screen that touch doesn’t work on, yet it works everywhere else. Any thoughts on what could fix this?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Try reseating the connectors. If that doesn’t fix it then you have a defective screen or a damaged connector/ribbon cable. While you have it apart inspect the cables carefully and make sure the connectors aren’t bent. If everything looks good contact ifixit and get it replaced under warranty.
War diese Antwort hilfreich?
Bewertung 0
The touch screen connector tab is broken so the ribbon cannot be click all the way, is there a way to replace/repair this?
Bewertung 0
1 Kommentar:
Reynald, is the broken connector on the ribbon cable or the motherboard? Can you post a picture of the damaged connector?
von
The ribbon cable is I think the one for the home botton which seem to work, my problem is really half of the screen that will not respond check the pic , one show some damage to the circonference of the screen that also could be the problem of the intermittent screen
Thanks for your input
Bewertung 0
Antwort hinzufügen
Anthony Chaya wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 91
