Zum Hauptinhalt wechseln
Die EliteBook 840 G3 Laptop-Serie wurde für den beruflichen Einsatz entwickelt. Das 840 G3 wiegt 1,5 kg und misst 34 cm x 24 cm x 1,9 cm
38 Fragen Alle anzeigen
Is there any hope to recalibrate this pack? eBay purchase
This one isn't as well setup as my first 840 G3, but it checks a lot of similar boxes other then the screen (768p vs FHD). However, for some reason which I will never get the seller removed the battery. Not a big deal so I thought since I know it uses the CS03XL and they are easy enough to replace. However it did not come with screws but that doesn't affect much, if anything.
The issue I am having with the pack is the battery refuses to calibrate - my other one is fine at 89% health but for some strange reason 3 previous attempts have not cleared the persistent calibration issue. I did get it on eBay as a “new” pack and have noticed capacity drops every attempt, so I suspect it may be a “new 0 cycle" pack which may be part of the issue. At this point I'm pretty confident my “0 cycle” theory is correct (and I only paid $27 and noticed a bit too late to be taken seriously -_-) but is there at least a good way to confirm this so I can just put this pack away for a emergency spare to get by and try to find a true 0 cycle that isn't rigged junk? I have an eye on another one I can try, but I'm suspicious of it too since the box is similar to this used pack that was probably reset.
Update (3/4)
Still dealing with calibration issues but it changed from the 21 error to 20. Still having trouble after 4 attempts…
So it looks like it may work (attempt 5)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
So yeah, my question is answered.
Warranty type 3. It was reset and sold as “new” when it really isn’t. As soon as I seen the warranty type and thought about it after attempt 6 still not working, I remembered exactly what that means - exhausted/replace.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Nick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 255
