Zum Hauptinhalt wechseln
Kleinere Version des ursprünglichen iPad Pro. Erschienen am 31. März 2016. Verfügt über ein 9,7-Zoll-Display, einen A9X-Prozessor und Speicheroptionen mit 32, 128 oder 256 GB. Erhältlich in Silber, Space Grau, Gold und Roségold.
Ipad will not turn on after battery replacement?
As the title states, I replaced the battery in an iPad Pro 9.7”, and now the iPad won’t turn on. No LCD display.
I plugged the iPad into a laptop and it was recognized by iTunes.
The installation went fine and without problems, and I’ve done it before, so I’m confused what the problem could be here. I’ve triple-checked all the connectors and everything that could be loose to prevent the LCD from powering up, and I can’t find anything. Any advice would be appreciated
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
was the battery connected when you connected the display? sometimes people can blow the backlight circuit when they connect the screen while the battery is connected. If you shine a flashlight on the display while attempting to wake it up or turn it on that's a quick and easy way to diagnose a blown backlight. also what did iTunes say when you connected the device? Was it in recovery or DFU mode?
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
It is in recovery mode
von
@janedoethethird glad you got it resolved!
von
Antwort hinzufügen
Jane Doe III wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 537
