Zum Hauptinhalt wechseln
Der iMac Pro ist Apples bisher leistungsstärkster iMac. Er ist mit einem 3,2 GHz 8-Core, 3,0 GHz 10-Core, 2,5 GHz 14-Core oder 2,3 GHz 18-Core Xeon W Prozessor ausgestattet. EMC 3144 / A1862 (ID iMacPro1,1)
Can I replace an 8 Core Xeon processor with a 18 Core Xeon Processor?
Can you replace the 8 core processor in a iMac Pro with an 18 core processor in a
iMac Pro?
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Yes! There is no problem as long as you use the correct CPU! 18-Core Xeon W-2191B
Now before you do this consider the clocking Vs threads issue!
  • 3.2 GHz 8-Core Xeon W-2140B
  • 3.0 GHz 10-Core Xeon W-2150B
  • 2.5 GHz 14-Core Xeon W-2170B
  • 2.3 GHz 18-Core Xeon W-2191B
A single threaded process will run faster on your current system and much slower on the 18 core! As the clocking has a large effect here.
But!! A multi-threaded application can leverage the multiple cores of the CPU, but you do need meter how many cores makes sense given your work load.
I often find people go crazy going with too large a chip when a middle version would make more sense!
So if your multi-threaded work load is using more than 2/3rds of your work day then consider the bigger chip, I would still see if the 14 core will be enough. If it’s less than 1/2 of your work day maybe the 10 core is enough.
Just like Goldilocks and the three Bears! There is a balance! Not going too small or too big!
Here’s a guide to get the display off iMac (27 Zoll, 2019, Retina 5K Display, Intel) Display ersetzen we don’t have an guide’s explicitly for the iMac Pro. Review the iMac Pro Teardown to an idea what’s involved.
iMac Pro Bild
Anleitung
iMac Pro Teardown
Schwierigkeitsgrad:
Mittel
iMac Intel 27" Retina 5K Display 2019 Display Bild
Anleitung
Schwierigkeitsgrad:
Mittel
15 - 40 minutes
War diese Antwort hilfreich?
Bewertung 5
Yes, you can replace but you should not doing it because your computer components will not bear the 18 core Xeon processor but if you have the TDP then it is possible
Bewertung 0
1 Kommentar:
FY - Apple sells the system with the 18 core chip so there is nothing wrong with the configs TDP.
von
Antwort hinzufügen
Doug Moore wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 2,329
