Zum Hauptinhalt wechseln
Erschienen im November 2016. Die PS4 Pro bietet verbesserte Hardware für 4K Spiele und Videostreaming.
387 Fragen Alle anzeigen
Help, identify missing motherboard component
Hello guys, making the change of the HDMI port within the repair, I accidentally removed this component, I can't find it and I have to replace it but I don't know what value it has and if it is a capacitor or coil, someone can help me identify it to be able to install one of the same value, I attach image waiting for some response.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
I am pretty sure it is a resistor and it should be identical mirrored image of the right hand side. Check the values of the capacitors (the bigger beige coloured components) on each side and if they are the same value you can almost be sure that the resistor (black, smaller component) is of the same value as on the other side.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Tomatoe Channel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 76
