Zum Hauptinhalt wechseln
13" Aluminium Unibody, 2,0 oder 2,4 GHz Core 2 Duo Prozessor.
574 Fragen Alle anzeigen
White screen but is working on external monitor
The display is working before but this morning as I was turning it on, for the first few seconds it is displaying the logo correctly but then some weird lines took over the screen then it turned white. I plugged it into an external monitor and it is working just fine (which means the GPU ain’t faulty) presumably that the LCD and its cable may have been damaged through wear and tear. So I replaced it with an LCD from a MacBook of the same model and the problem still persists. Is there a component on the motherboard responsible for this display failure?
The screen during boot (It also has a display after waking from sleep)
The screen after a few minutes of warming up
I was not able to take a picture of the lines appearing on the screen (my camera can’t pick it up)
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If your external is working then you’ve nailed the issue down to the internal display. Likely the T-CON board which drives the display failed its located at the bottom of the LCD panel. Here’s the needed part: Unibody MacBook Complete Display and here’s the guide MacBook Unibody Model A1278 Display Assembly Replacement
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Alrighty. But before I buy a replacement, could there be any components that likely cause this issue (aside from the T-CON?)?
von
@tinkerwarr10r - Did you damage the logic board connector for the display (and/or the LVDS cable)? Take some pics of the logic board connector and the cable end so we can see things.
von
Antwort hinzufügen
Francisco T. wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 167
