Zum Hauptinhalt wechseln
Erschienen am 4. November 2017. Modell A1865, A1901. Erhältlich als GSM oder CDMA / 64 oder 256 GB / Silber oder Space Grau. (Genauso ausgesprochen wie "iPhone 10")
1199 Fragen Alle anzeigen
Battery keep maintenance message
Hi there,
I replaced my battery and used icopy to keep sn.
when I plug in 3utools
3utools show 100% ok.
But in setting iphone x keep the message maintenance and if i click show 77% same percent old baterry
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Changing the serial number to the original one will have no effect. You also need to transfer the flex assembly from the original battery as that is where the chip is that is linked to the phone. You need special equipment for this procedure like a micro spot welder and micro soldering iron.
War diese Antwort hilfreich?
Bewertung 2
6 Kommentare:
But its just happens with X?
coz another one like 8 plus / xs / 7 I use icopy and works well.
von
@diogotm From the X up. I don’t see how it would have worked on the XS. There are videos on YouTube showing the procedure.
von
@diogotm Well there’s your problem. They just replaced the battery without copying the serial number over.
von
That’s make sense, if you copy serial to show 100% in 3utool you can’t change the percent health in iPhone settings
But if you DONT use icopy you have 100% health in iPhone setting. BUT if you plug iPhone in 3utools they show the red message “the battery my be replacement”
OMG apple apple
If I like the both 3utools 100% and iPhone setting health 100%
I need to swap a microchip, right?
Thank you very much your patience and your answers
von
1 weiteren Kommentar anzeigen
Bewertung 0
Antwort hinzufügen
Diogo Thomaz de Melo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 137
