Zum Hauptinhalt wechseln
Im Juni 2017 brachte Apple die Neuausgabe vom 13" MacBook Air heraus. Es erhielt den neueren Broadwell Intel Core i5 Prozessor, die Leistung und Akkulaufzeit stieg dadurch etwas an.
423 Fragen Alle anzeigen
Why isn’t my MacBook turning on after I replaced the battery?
My MacBook was not turning on after charging (Kept seeing orange light) so I got a new battery thinking it is a battery issue. Now that I have replaced the battery with a new one and charged it for 4 hours it’s still not turning on. I am at odds with this as the laptop is only 2 years old and I have hardly used it. I don’t know what to do next, if any can help me figure out how to get it working again?
Update (06/18/2021)
Thanks for the reply, the charger looks to be working fine, mag safe pins and contact look okay too
I’ve not replaced the charger as it seems to be working order. Only the battery which is from Ifixit ? I have tried disconnecting the battery and reconnecting and trying the power button again but nothing is working. Seems like something has died in there but I have no idea what it could be.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Sharon - Not good ;-{ If the charger and the DC-In board are AOK, then you either got a bad battery or the charging logic internally is having a problem.
If you can lets download and run this gem of an app get a better view of things! CoconutBattery take a snapshot of the apps main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von
Hey Dan, i don't think i can download this Cocunut battery app as I can't even power up the macbook :(
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Often the charger also needs replacing or the DC-In board.
Let check the connections first!
Is the MagSafe cord damaged in any way? Cuts, bunched up in areas, or not smooth across its length.
Is the pins clean and are the outer two pins at the same height (the middle will be a bit lower)
is the systems MagSafe contacts clean and shiny is the plastic insulator area also clean? Use some isopropyl alcohol with a cotton swab (Q-Tip) to clean things up, then use a fresh soft pink pencil eraser to polish the contacts if they are not clean.
Dirty and clean!
If yours looks like this then you need a new DC-In board
The last issue is the hardest to tell! If you replaced your charger did you buy it directly from Apple online or at their store? A good number of chargers sold from other sources as real are not! These knockoffs are so good you can only tell by weighing a known real unit from the fakes with a good scale. The fake will be a bit lighter.
Don't Replace Your MacBook Charger With a Cheap Knockoff
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Sharon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 53
