Zum Hauptinhalt wechseln
Die kleinere Version des iPad Pro, herausgekommen am 31. März 2016. Ausgestattet mit einem 9,7" Display, dem A9X Prozessor und wahlweise mit 32/128/256 GB Speicher. Erhältlich in Silber, Grau (Space Grey), Gold und Rose Gold.
New digitizer screen unresponsive
I have a 128GB iPad Pro 9.7” screen became unresponsive about a year ago. Just recently replaced screen and digitizer. iPad is still unresponsive to touch but screen display works. I have checked all connections and updated but still will not work any suggestions or am I wasting time and money?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
hello Ryan,
unfortunately, ipad pro 9.7 has a problem with the compatibility of mounted parts. It happens that the factory-installed ones do not last the assumed working time. Especially often (with yours case, it's over 50 times in my career. Where's the world?) I think it has to do with the problem of the parts from the subassembly provider. Take out the main board, remove the covers of the second submodule, in the second section. A large inductor will be faulty - but not grounded! Replace it with a new one or solder to two others, with a total value similar to the one originally installed (I did it at my tablet). The touch function is back.
PS: make sure in advance that the resistance value of the pads from the touch circuits to the connectors has a measurable value. You may find that the lack of touch is due to a broken connection underneath them (two pieces) - which also happens quite often, especially when someone tries to remove the motherboard.
My advice: repair is painstaking (benedictine) and quite difficult for a less experienced person. If you don't see yourself in this, find a good repair shop or sell your faulty device. These still hold the price, especially with the original screen assy.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Ryan Covey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 146
