Is it possible to replace the charging port?
The charging contacts are getting very damaged and causing inaccurate charging. Is there a way to buy this piece and replace it, how do I replace it? Thank you. Fitbit Alta HR
Ist dies eine gute Frage?
if you can access the port and the board it should be possible to replace the charging port.
if you dont have the proper tools, IE hot air station, solder, flux, new port it could be more costly to do it yourself as opposed to sending it to a repair shop.
hope this helps!
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 282
