Zum Hauptinhalt wechseln
Model M4753 / 233, 250, 266, 292, or 300 MHz G3 processor
20 Fragen Alle anzeigen
Can a Wallstreet running Jaguar use an external WI-FI card?
I have just won an auction for a spares/repair Wallstreet. Would this be able to cope with an external WI-FI card? I gather that it should be able to run Jaguar. I have seen one website selling plug in cards to allow use of USB & Firewire devices and I did spot an external WI-FI card but in small print it talked about 10.4 (Tiger) only. Has anyone been able to use wireless connections via a Wallstreet?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
If one of these answers solved your problem please hit the accept button to the upper right of the question so we can take it off the unanswered list. Thanks so much
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The PB Wallstreet will run up to Mac OS X 10.2.8
I'm sure you can get a wireless card that will work with the Wallstreet but I can't say for sure which one myself - but I would go over to xlr8yourmac.com or PowerBookwireless.net and take a look there for a solution
War diese Antwort hilfreich?
Bewertung 5
3 Kommentare:
Looked it up--can be done. You nailed the source. Ralph
von
Excellent. Just what I needed to know. Thank you. Mal.
von
I used to use the Orinoco gold card with my wallstreet. it worked fine
von
The original Airport Base Station used Orinoco cards. Either a gold or silver orinoco card will work. In OS 9 no drivers are needed and they are seen as true airport cards. For jaguar you need to download the the drivers from sourceforge.
http://wirelessdriver.sourceforge.net/
Bewertung 1
Yes, U can use a wifi card with Wallstreet under Jaguar os X.2. I have the same configuration & it works fine. I use a Belkin card.
Bewertung 0
Antwort hinzufügen
Mal Partridge wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,915
