Zum Hauptinhalt wechseln
1,7 GHz Dual-Core Intel Prozessor (Turbo Boost bis 2.6 GHz) mit 3 MB geteiltem L3 Cache
139 Fragen Alle anzeigen
Display not working when using a certain ssd
I was trying to reinstall the MacOs on my old macbook but it doesnt seem to boot anymore with the current ssd. If i unplug it or use a different ssd i can boot.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
What is the SSD's you are working with? Make and Models
von
@danj Im using the original ones that came with it. I believe its a 128GB Toshiba
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I’d boot from an external source, reformat the dive, run Disk Utilizes on it and then try installing a new system from the external source.
This failing, it’s time for a drive replacement:
MacBook Air 11" Mitte 2012 Solid-State Drive austauschen
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Even though it was working perfectly fine before? I had reinstalled the OS then it turned off again so i reinstalled after, after that is when it no longer booted. If the SSD is plugged it, it doesnt boot past the chime. If i tkae out the ssd i can do command + R to recovery mode easily
von
Don't try to do a restore from a drive that's not in the machine, The recovery files and your data are all on the same drive. So do the the work on the internal drive from an external.
von
This SSD has a known issue! Apple issues firmware fix for Toshiba SSDs in 2012 MacBook Airs & Apple Recalls Mid-2012 MacBook Air For SSD Replacement – 64GB and 128GB SSD Systems Affected
Its a bit on the late side, but its possible you just don't use your system that heavily so it took a bit of time.
Sadly, Apples extended warranty program has ended for your system. Time for a new drive!
The Apple SSD is a bit faster than the OWC drive, but its more expensive.
OWC Aura Pro 6G SSD for MacBook Air 11" and 13" (Mid 2012) Bild
Produkt
$45.99
Bewertung 0
Antwort hinzufügen
Jun Hyeok Yoon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 37
