Zum Hauptinhalt wechseln
Erschienen am 4. November 2017. Modell A1865, A1901. Erhältlich als GSM oder CDMA / 64 oder 256 GB / Silber oder Space Grau. (Genauso ausgesprochen wie "iPhone 10")
1199 Fragen Alle anzeigen
Would screen replacement fix green lines/flickering on screen?
What are the chances that a screen replacement would fix a flickering screen that partially does not display an image, following water damage?
My iPhone X was dropped in water, and has now dried out and seems to be functioning except that:
  • screen has a slight flicker (light horizontal lines quickly oscillate across entire screen)
  • the top right corner is not displaying an image (has a combination of bright green lines and black),and
  • the top left corner has a dimmed image.
While the phone was drying out, at one point it had vertical green lines running down the length of the screen, though this does not appear anymore.
Picture of the current error:
https://drive.google.com/file/d/1berZouJ...
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Green lines and flickering is usually indicative of physical damage to the LCD or OLED panel underneath the glass, and would most often be resolved by a replacement screen, however with the water damage there may be a little more to it. If the device actually functions completely fine now with no errors or anything you might have gotten lucky. I’d recommend taking out pretty much every component to scrub down with some alcohol based cleaning solution that’s safe for electronics, and then put it all back in with the original screen(also clean connectors of screen flex cables) and see if it’ll work. If the issue is still persisting then replace the screen and everything should be fine!
If possible it may even be worth going to a reputable repair shop to see if they can diagnose whether or not it’s worth getting the screen replaced.
War diese Antwort hilfreich?
Bewertung 1
help my phone screen is broke and my dad is going to be !#^&@@
Bewertung 0
1 Kommentar:
p
i
s
s
e
d
_
von
fixed the same problem by bearing my iPhoneX in beg of rice for few days to finish drying off its internals after successfully resurrecting my old Motorola in the same way from a drop into a toilet bowl years before:-)
Bewertung 0
Antwort hinzufügen
Prv8E wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 64
Insgesamt: 3,663
