Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
iPhone 7 Stuck in Boot Loop
Hello there,
I have an iPhone 7 thats stuck in a boot loop after replacing the lightning cable. The phone has had some problems before so I’ve done past repairs such as a screen replacement and battery replacement. At some point the home button stopped working so it was used with assistive touch and it still worked. Eventually it stopped charging, so I replace the lightning port, first time it doesn’t charge so I return it and order a new one and install it, finally it starts charging again but is immediately stuck in a boot loop. First thing I try is replacing the battery with the old original Apple one it used to have, that didn’t work so I ordered a new battery and tried it but it still didn’t fix it. Would the issue be caused by some malfunctioning component such as the no working home button (despite the phone booting fine while it didn’t work before)? Or is the board dead? Could it be the new lightning port that I installed thats causing the problem? Any ideas?
Thanks
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
iPhone screen replacements can be a tricky thing, but you seem to know a thing or two. Are you still using the original home button? Also, have you tried resetting via the DFU mode?
von
@minas Yes I'm using the original home button. Since its stuck in the boot loop I tried but haven't been able to boot into DFU mode.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It will most likely be a parts problem. The first thing you need to try is disconnecting the top flex and see if it still boot-loops as this is the major cause on the 7 series. If it it’s still the same disconnect the home button flex and try. If that doesn’t work it will either be the charge port or battery.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I already tried booting with different combinations of flex cables connected and disconnected and nothing worked. Tested it with 3 different batteries and nothing worked either so I'll try replacing the charging port again. Thanks.
von
I replaced the charging port again and its still in the boot loop. Dead logic board?
von
Did you try hard reset your iPhone?
You may check solutions here, or refer to this thread: iPhone 7 Boot Loop Restore did not work
Bewertung 0
1 Kommentar:
I tried those already and it didn't work.
von
Antwort hinzufügen
Thomas Metaxas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 142
