Zum Hauptinhalt wechseln
The Honda General Purpose Motor model GX160UT2 is an air-cooled, four-stroke, overhead-valve, 163 cc, 4.8 HP (3.6 kW) engine. Supporting sub-models QWX2, QX2, RH2, TX2.
Pull cord mot starting
Pull cord will not pull. Flywheel works perfectly, when i pull the cord, and then align it back , it does not retract. The flywheel rotor has limited movement
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Broken spool spring - common failure. If you're not familiar with recoil spool repair, take it to someone who is. You could try YouTube, but mistakes with highly spring tensioned objects get ugly Fast.
von
Einen Kommentar hinzufügen
1 Antwort
Definitely the spool spring. This can happen just by use, weather conditions, or by impacts on that side. Be careful when repairing the spring, like Kevin says it can get ugly fast. I have gotten hit in the face by one before.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Trent wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 16
Letzte 30 Tage: 42
Insgesamt: 281
