Zum Hauptinhalt wechseln
The Acer Spin 713 Chromebook is a 2-in-1 convertible laptop designed and manufactured by Acer. It is part of the Spin series and is specifically built to run on the Chrome OS.
How to remove bios protection on Acer 713-2w Chromebook
Where is the bios protection screw or other mechanism on an Acer 713-2w Chromebook and how can bios protection be removed to flash a new bios and install a Linux operating system
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
In the settings app, do you see an option for Linux or Linux(Beta)?
von
Yeah. I used crostini, crouton and qemu/KVM to test linux on my Chromebook before posting this message. The best approach for me was qemu/kvm running Manjaro mate. The performance was good, but as much as I wanted to like chromeos that was not to be.
The Spin 713 bios is locked by a Google security chip on the motherboard. It appears that the security chip can be disabled and a new bios flashed to replace it.
Chromeos will be gone but it seems just about anything else can be installed following the installation instructions for the OS of choice.
In a few days I will receive the Suzyqable cable that is necessary to disable the security chip.
I'll post again as to my success or failure after I've received the cable.
Thanks for your reply to my question.
von
@runrun22
SuzyQable
You should make a technique-guide explaining some of its connecters and hat yoy can do with it, might as help you!!!
von
Einen Kommentar hinzufügen
1 Antwort
all you need is a SuzyQable and a bit of trickery.
there are turorials on youtube how to use them
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
L S Colby wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 448
