Zum Hauptinhalt wechseln
Das 3a gehört zur dritten Generation von Pixel Smartphones, ist eher preisgünstig und hat die gleiche Kamera wie Googles Flaggschiffe. Erhältlich in Schwarz (Just Black), Weiß (Clearly White) und Purpurartig (Purple-ish). Erschienen im Mai 2019.
After Display Replacement Lines Apeear on the Display.
After a display replacement, I get horizontal lines on my phone’s new screen. The phone also has issues in dark conditions as the phone acts like it has 8 dimming zones. I was grounded during the display replacement ( Common Issue ). As the display is powered on the lines progressively turn from light grey to black. I don’t know what to do about this, so do y’all have an answer?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
From what you are describing it may be one of the following:
  1. Bad connection of the LCD cable. Did you try disconecting it and reconecting it?
  2. Bad LCD panel. It may of have been defective from the start, or damaged in shipping or during the repair process.
  3. Pry damage of a component near the display connector on the motherboard. This one is easy to make and hard to repair. If you have any way to magnify your view, have a carefull look at the components near the connector. If one was accidently pried off you will see 2 solder pads with the solder that appears rough and ruggged. If so that components need to be reinstalled. Be carfull, there are often No Stuff pads. Which are pads that never had anything installed on them in the first place. You can tell those appart when looking at them, the solder will be round and puffy vs rough and rugged.
The nice thing about pixel screen replacement is that you don’t need to access the full motherboard to replace the screen, which really limits the potetial problem areas.
Hope this help ( I would not be too worried about static discharge problem, and it very rarely an issue)
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
Thank you but unfortunately, none of these fix the issue. I've disconnected and reconnected the display about 15 times, have cleaned both sets of pins, and have verified that no pins are broken on each of the connectors. I did replace the battery of this phone but have not touched the motherboard other than using a spudger to remove the display, battery, and force sensors (I don't know a better word for them); taking off the midframe I see no visible damage to the motherboard under a magnifying glass. I have contacted ifixit and have stated the replacement process. Thank you for your suggestions.
The best,
-Chris
von
Good work, odds are that the new screen will resolve the problem then :)
von
i just installed new screen on pixel 7 pro. followed instructions as directed.
immediately got a vertical purple line on the new screen. please advise on further instructions thank you.
von
Antwort hinzufügen
[deleted] wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 79
Insgesamt: 3,658
